REVIT ARCHITECTURE PLEASE HELP
Hi i wanna know if I can download Revit architecture on Mac, by using internal partition with Windows 10 home? Or I have to use only Windows 10 pro. I think that probably it will work anyway or is it simply incompatible? Let me know as soon as possible.
Thank you very much
Hey.
Check this: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
You can install Windows on Bootcamp on Mac. Is the most suggestable.
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
Yes, but it's different if in boot camp I will install "Windows 10 for home" or "Windows 10 pro"? that is my problem. I don't know if I can use Revit on the home version of Windows, do you if I can use Revit on it??
Pro or Interprise. Not on Home.
And must be installed at Windows 64 bit.
