Revit Architecture 2018 solar panel family creation 3D modelling on revit
1 ANTWORT 1
Nachricht 1 von 2
2502 Aufrufe, 1 Antwort
Good evening everyone;
I'm hopefully going to begin working as a Revit draughtsman and I will be designing "solar systems" that means placing and designing pv/solar panels.
I'm having a problem creating my own pv panel with racking:
I'm not that great at 3D modelling on revit arch. So I have opened the solar panel family file in sustainable design.
However when it comes to modelling the racking (the frame that can set the angle of title) I'm having dificulty.
Is there anyone who who could suggest a solution.
PS is there an autodesk revit family library where I can search for the pv module and it's racking?
I've attached two screen snippets/views of the model I'm trying to do this on (the racking/sweep is supposed to be directly under the panel and I'm struggling to do that).
The solar panel family is roof host based which means, to me, that the panel will lie parallel and flush on top of a roof.
What I want to achieve is to have a racking part of the family that creates the "tilt" independent of the host, this means that if I wanted to achieve a 23 degree tilt on a roof that has a 20 degree pitch then the racking would increase in height to create it.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
It's all about Work Planes.  Here's a good place to start learning about them:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
