Revit Architecture 2013 / Problem of Rendering
When I open Revit Architecture 2013, there is a message popping up and showing that
The Rendering Features are currently disabled.
DarrenP
did you do what it says?
try installing the material librarys
DarrenP
Yes, I uninstalled and installed it for several times and also checked the installation part of Material Library, but now it was totally unsuccessful to install it when the installation progressed.
Before I re-installed it, I still could use Revit without the function of Rendering.
However, now it always shows me "Failed to install" in the middle of installation.  (>_<)
Thanks for replying.  (^_^)
I solved the problem myself already.
I removed and uninstalled all software of Autodesk such as Revit and 3DsMax.
Then I re-installed them.
