Revit Architecture 2012 Error Message
Message 1 of 9
I am running Windows 7 Professional 32 bit and I keep getting an error message saying "An error has occured while drawing the contents of this window.  This window shall be closed."  This happens very often, and randomly.  I also had alot of trouble installing Revit Architecture 2012 yesterday from the disk, it kept freezing and I ended up downloading it from autodesk's website.  I am wondering if anyone has any solutions to either of these problems?
Replies (8)
Message 2 of 9
Sorry I meant a 64 bit os
Message 3 of 9
kathryn.langan
Hi Kate,
I would suggest taking a look at the following Technical Solution on our Knowledge Base: An error has occurred while drawing the contents of this window.
Let us know if this helps!
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Message 4 of 9
Hi kathryn.langan
I try the link that you put in your comment but it does not work for me. any other suggestions..?
Message 5 of 9
Are you using a Wacom tablet?  If so, you can try to disable the "Tablet PC Input Service" in Computer Management.  This has help.
Message 6 of 9
Katie, thank you so much, I am a brand new user, Revit would not even allow me to draw two walls without giving me this error message and shutting down.  I unchecked that box and it works fine now.
Thanks again
Drew
Message 7 of 9
kathryn.langan
Great Drew - I'm glad it helped!
Katie Langan
Autodesk, Inc.
Message 8 of 9
I also want to thank you Katie for the solution. It worked like a champ and now abel to use Revit Architecture 2012. You are the greatest
                                                    Thank You,
        Rich
Message 9 of 9
Whenever I change my Rendering Settings the programme stops working and then automatically closes itself.
