Revit - Archicad Worfflow
0 ANTWORTEN 0
Nachricht 1 von 1
MRomeroTBC4L
74 Aufrufe, 0 Antworten
I'm working on a project that requires a lot of back-and-forth between ArchiCAD and Revit. Our workflow involves extending the data exchange from ArchiCAD to include internal layouts and internal doors, while our main focus is on external work and external doors.  I've run into a few issues that are making things tricky. SO any advice/experience is welcome.
  1. Shared Coordinates:
    • When I export the IFC from ArchiCAD, elements like walls, doors, and floors are in the right place, but scope boxes and grid lines aren't. scope boxes position.png
  2. Door Openings Visibility:
    • Is there a way to see the door openings from ArchiCAD in Revit? I found a guide on adding 2D detailing for doors and windows, but I couldn't get it to work. Also, we can't see the doors in floor plans, even though they show up in 3D. Any ideas on how to fix this? doors visibility.png
  3. Visibility Issues:
    • Even though we're using the graphic display as Hidden Line, the view looks like wireframe. Does anyone know how to solve this?
We are using Revit 2024 and ArchiCAD 28, and the IFC Model Exchange with ArchiCAD for Revit add-in.
Attached you can find the revit file with the IFC from Archicad internal layout.
Any advice or resources you can provide would be greatly appreciated.
Thanks.
0 ANTWORTEN 0
