I have a Dell XPS type P56F002. Revit 2014 opens fine but once changing between layers the layer shows as blank until you minimize Revit and then maximize it again. Running the latest version of windows.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Sorry that was a bad description by me there.
Under project browser when you click on one of the objects the big area that should show the floor plan for example is blank until you minimize and maximize again.
So, if I understand you correctly, when you double-click on a particular Floor Plan View listed in the Project Browser, the Drawing Area shows nothing. But when you click on the Window's "Minimize" and "Maximize" button (at upper right corner of the screen), the Drawing Area then shows something. Is that about the size of it?
