Revit and SCIA Engineer
1 ANTWORT 1
Nachricht 1 von 2
mairh_tsek
643 Aufrufe, 1 Antwort
Hello all,
Is there someone that has used the Revit with Scia Engineer?
We are interested to do the analytical design in Revit (as much as possible) and to import the model in Scia for the calculations.
Do you know if it works well?
Could you tell me which plug in I need to install  and if it is free?
Thank you a lot for the information.
1 ANTWORT 1
Nachricht 2 von 2
jccoyap
als Antwort auf: mairh_tsek
Hello!
This is a late answer, @mairh_tsek probably has already test that workflow, but as I found this post I think is should not stay unanswered.
Scia can read and write analytical model from Revit. They have a plugin made by CADS. This is the link (log may be necessary)
https://www.scia.net/en/support/downloads/plugin-revit-structure-scia-engineer
We can find some videos of the process in Scia youtube channel, por example
https://www.youtube.com/watch?v=1OLwvtnWNLc&t=180s
(I did not find a video using the version 21, than uses a new interface)
Coya
