Revit and Lumion
Revit and Lumion
Revit and Lumion
I tried to visualize a Revit project on (Lumion). Although I have Lumion installed on my PC, Revit does not find or recognize it in (Add-Ins -> External tools). See the attachment.
This step is necessary to create a format of the project to be managed in (Lumion). How can I solve this problem?
Thank you.
jeffrey.sin
Hi @Anonymous,
Maybe this information on Add-in Integration can help out?
Jeffrey Sin
Autodesk Customer Support
Thank you for your response.
I found the solution. I must install (Lumion Collada Exporter) from Autodesk. See the link:
https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3Arevittolu...
After installation, I got the possibility to creat a file format which is suitable to be used in Lumion.
Thanks again.
thnk u
