Revit & MS Onedrive
1 ANTWORT 1
Nachricht 1 von 2
julia_ashall
1187 Aufrufe, 1 Antwort
Revit & MS Onedrive
Due to remote working we have started to work with our files on onedrive, when I sync the file and open from another location it loses its links to the materials library.
Is there anyway of retaining these links to that the materials do not need uploading each time it is opened.
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
Lance.Coffey
als Antwort auf: julia_ashall
Thank you for the question @julia_ashall!
Two things to look for:
 Regarding, “synching” Revit models on a OneDrive folder, if you are referring to synchronizing a local model to a central model stored on OneDrive, I would suggest reviewing the following article for information on what can happen when working in such an environment (if you have not already done so): Using Revit files on Dropbox, Box, OneDrive, SharePoint, ShareFile, Google Drive, Autodesk Drive
Lance Coffey
Technical Support Specialist
