Revit 3D view is distorted
Hello everybody,
I woke up this morning to a distorted Revit model
last time I worked on it it looked better. but now all the 3 view in the model look distorted and weird.
I think it had to do with several options in the model but I'm not sure.
I tried to update the driver for the Nvidia Quadro p1000. it didn't work.
did someone see something like that before? how do I fix this?
Kimtaurus
The view is corrupted.
The only solution I know is to delete the view in the Project Browser and recreate it.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Yep...corrupted view.  Also suggest putting in a building pad for your topography and a roof for your sidewalk vs a subregion.
Distorted 3D views also happen when model is located more than 10 miles from the Internal Origin. FWIW.
