Revit 3D view display issue
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
a.bratkowskiPKPRG
632 Aufrufe, 3 Antworten
I am having a graphic display issue in the 3D view, regardless of the Revit version I keep coming accross the display problem. It looks like a wireframe (a mesh) is visible even though hidden line style is set.
Is there a fix for Revit 2023 that would solve the problem? Thanks a lot, kind Regards!
Andrzej
Tags (1)
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
have a look at:
  • Graphics>Discipline  (if , for instance you are in Structural and the Wall is Architectural....)
  • see , if you have not on override of transparency
Constantin Stroescu
Nachricht 3 von 4
Well, thank you so much, but I tried both and I did not fix it. The only solution I found so far is to completely erase the 3D View and to create a new one from scratch - by Default 3D View option.
Andrzej
Nachricht 4 von 4
jacob3VF9Y
als Antwort auf: a.bratkowskiPKPRG
Make sure you have a template created to go before deleting the original view. But yes, starting a new view from the default 3D view is what worked for me as well.
