I just started working with a model created by a third party vendor. This is a multi-family project so all the Residential Units have been made into model groups. There are some mistakes in the Units that I need to correct but when I select the model group and click the "Edit Group", Revit goes into group edit mode and I can edit the model group but the "save changes" check mark and "cancel changes" x are not available in the ribbon. Furthermore, the model becomes stuck in group edit mode and the only way I have found to get out is Undo.
Gelöst! Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
Check this article: In-group-edit-mode-Finish-and-Cancel-buttons-are-missing-from-Revit-ribbon
For now, you can use the Shortcuts to Finish Group.
Try using the following keyboard shortcuts for the "Edit Group" panel:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Hi @t_weiland
Thanks a lot for posting your question to the forums! Has the solution suggested by @ralphdenhaan helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Perfect @t_weiland Glad you got sorted.
Jonathan Hand
