Announcements
Revit 2025 Setup File Crashes
ahmed.elhawary73
ahmed.elhawary73
Revit 2025 Setup File Crashes while preparing install as obvious in the below video despite the following:
  • I've already installed all Revit Version from 2019 to 2024 and there is no problem
  • Setup Source Working on another desktop
  • I've updated all net frameworks and still the same issue happens
RDAOU
@ahmed.elhawary73
Hard to tell without any logs that show what is happening in the background. Did you use the online installer or the offline one? from the folder name in that screenshot it appears like you have used the online one (might be mistaken) the offline installer download 2 files a RVT_2025_NA_win_db_001_002.exe and a RVT_2025_NA_win_db_002_002.7z
  1. You run the exe and it extracts the necessary from 002_002.7z
  2. When you log in to your account, instaed of hiting download, use the drop down menu and select the offline installer
ahmed.elhawary73
I have the offline installer, I tried to download it again from Autodesk to try again but didn't find links can you help?
