Revit 2025 - Missing External Applications
t_williams2DTYFY
Observer Observer
t_williams2DTYFY
Observer
Observer
Hi All,
I work in the IT team for an enterprise where we deploy out Autodesk to all our computers , including Revit.
Recently on about 1/3rd of the computers , every time you launch Revit , it provides an error message and says Revit cannot run the external application. I'm at a bit of a loss, I've tried uninstalling (Which is difficult enough with autodesk software...) and re-installing and its about 50/50 on whether you get that error or not. We've also completely re-imaged computers and its the same outcome.
I believe we deploy Autodesk (Revit included) from a network share using batch files, so this could be the issue. Not sure if Autodesk has guides on deploying their applications Enterprise wide?
Images attached.
Thank you.
Simon_Weel
I've seen this before. The 'resolution' might be to re-run the installer. Don't remove anything - just re-run the installer. It sometimes takes a couple of times to get everything installed. The home-grown Autodesk installer has it's flaws.
There are some guidelines for enterprise-installs, but it's brief.
Deploying Autodesk software to many computers
Installation Help | Test the deployment and distribute products to workstations | Autodesk
t_williams2DTYFY
Observer
Observer
Hi Simon,
Cheers for getting back to me. I thought re-running the installer but it didn't seem to be re-running (I've only tried on this one PC so far , will try to re-run the installer on other PC's with the problem too). I've checked the logs and it seems to be related to something called an UPI? I'll attach a screenshot of the logs and a screenshot of where I've found the UPI code in the xml. I'm not too sure on what the UPI code indicates or why it might be erroring out, any ideas?
Simon_Weel
As you discovered, the UPI codes reference those add-ons. If you search xml files (Notepad++ search in files-feature) in the image folder for those UPI2 codes, you'll find the xml file for that add-on and it will list the accompanying .msi / exe file. So for those failed installs, you could try to manually installing the missing bits. Or hack together a script that will install all missing components, whether they are missing or not.
A 'clean uninstall' as recommended by Autodesk usually doesn't do a clean uninstall. My experience is there's a lot of leftovers after a 'clean uninstall', making it difficult to re-install stuff. In those cases, I search / delete the registry for every 'Autodesk' line and also search / delete msi files for every 'Autodesk' file. It's messy....
Edit: could very well be you get the message xyz is already installed when you try to install a missing component. In those cases, the Microsoft Troubleshooter could be a help.
