Hello I tried to import csv file into revit and I still get the same error. Tried to change commas instead of dots but the results are still the same. Any ides what could be the reason?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
the contents of B1 are wrong
...again: 3 columns of numbers for x, y and z
I know what you mean, but when I open the csv file it looks different to yours.
Save it to TXT (MSDOS) and try using that to create Topo.
BTW: what are the Units? Those are extraordinary numbers.
The z units are elevation (meters). The first two are lat and lon. Surveyers in the czech republic use jtsk coordinate system. Anyway tried to save it as txt msdos but still the same error. Here is the file saved as txt (MSDOS).
Yeah should be correct. But still Im trying to figure out what I'm doing wrong.
Your file is working fine, so should I try to delete all the commas and dots in the file next time?
Not the commas. You want comma separated values - just like in my file. Open it in notepad and see.
But it causes little bit of problems when you delete the commas. I have to keep the commas in the file otherwise the units will be messed up. it creates topography much bigger than it should be.
we're talking two different things here. I'm talking about the txt file format - comma separated values. You're talking unit formatting/presentation. Use a decimal point instead of a comma in the txt.
...and select the proper unit conversion upon creation of the Topo.
...just to clarify, I didn't mean replacing the grouping commas with decimal points. I meant make the values decimal values.
Hello, sorry if Im bothering you. Now it works fine for me. And thank you for your answers. Helped me a lot. Thank you.
You aren't bothering me at all. All's good and you're very welcome.
Have a good day.
