Revit 2025 crashes every time after closing a file
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
ylirar
529 Aufrufe, 2 Antworten
Started using Revit 2025 this week and everything works great until I close a project/family etc. file. It's a guaranteed crash every time no matter what. Here's all the things I've tried so far:
  • Multiple PC reboots
  • Disabled all addins
  • Deleted Revit.ini in UserDataCache and AppData
  • Uninstall and fresh install (tried both custom install and basic install)
  • All available Windows updates installed
  • Updated to latest graphics card drivers
I'm running out of ideas. Previous versions of Revit (2022/2023/2024) work just fine.
Revit version
25.2.0.38
20240715_1515(x64)
2025.2
Windows 11 Enterprise 23H2
Build 22631.4317
Windows Feature Experience Pack 1000.22700.1041.0
BTW my colleague tried this with a similarish PC without crashes but he's running Windows 10.
2 ANTWORTEN 2
Nachricht 2 von 3
TripleM-Dev.net
als Antwort auf: ylirar
Any Addins?
Revit 2025 functions differently regarding the API/Addins/Dynamo etc.
Could be a R2024 addin version is also loaded into Revit 2025.
Also look into the journal
Nachricht 3 von 3
ylirar
als Antwort auf: TripleM-Dev.net
Yes I do have addins and had them disabled (moved away from C:\ProgramData\Autodesk\Revit\Addins\[Version]), but now that you mentioned them I took a closer look and found out there are three additional paths where they could reside:
C:\ProgramData\Autodesk\ApplicationPlugins
C:\Users\%USERNAME%\AppData\Roaming\Autodesk\Revit\Addins\[Version]
C:\Users\%USERNAME%\AppData\Roaming\Autodesk\ApplicationPlugins
 Turns out there was a Leica CloudWorx hiding in the first path mentioned above and that indeed was the cause for the crashes. So problem solved, thanks for nudging me in the right direction!
