Revit 2025.4 Constant crashing
pprivado
Message 1 of 22
pprivado
Revit 2025 is constantly crashing. It began about a week ago and initially seemed relatively benign. Now it is crashing regularly, and it is essentially unusable. It will crash constantly on startup. There are instances where I will open a file, but I will try to open a view within that file, typically, I try the 3D view, and it loads for a few seconds and crashes. It will also struggle with a specific file, but I doubt the file is the issue. In this case, it will reach approximately 50% and then crash.
I have performed clean uninstalls (both Revit wipe and Autodesk wipe), tried running Revit as another user, and opened both existing and new files. Additionally, I have uninstalled all plug-ins. I have the same Revit 2025.4 build on my laptop and have been using it, so I know the files are not corrupted.
Frankly, I am at my wits' end, as I am at the very edge of my computer skills. I have some suspicions regarding my CPU, as it is not the most reliable and is very power hungry, but I highly doubt it's the issue. Here is some context regarding my specific machine:
OS wise:
Windows 10 Pro 22H2
Hardware-wise:
Intel i9 14900K CPU
AMD 6900XT GPU
64 GB DDR5-6400 Dual Channel RAM
2TB PCIe 4.0 NVMe M.2 SSD
850W PSU
Any help is greatly appreciated!
I have attached some of the most recent crash journals:
Replies (21)
Message 21 of 22
Marc.Cacciola
Community Visitor
Community Visitor
This indeed is the issue.
Message 22 of 22
pprivado
Hello, yes, the Intel processor was definitely the problem. I switched over to AMD, and it solved all of my issues. I replaced that I9 with the current AMD Ryzen Flagship.  To your point, I have been keeping up with all of my BIOS updates and such. I didn't bother with RMA'ing the I9; I gave that CPU and the accompanying bits to a friend for tinkering.
