Revit 2025.3 Schedule Grouped Headers misaligned
1 ANTWORT 1
Nachricht 1 von 2
bansalmP529H
72 Aufrufe, 1 Antwort
Every time i try use the group function in a Multi-Category schedule the headers have extra space and vary in alignment. Yes, I did uncheck the "Blank Row Before Data in the Appearance tab. Still the same behavior after I group the second parameter.
Also, after I group a second parameter, I get either a split in the same group value or a gap between rows.
1 ANTWORT 1
Nachricht 2 von 2
jay_colcombe
als Antwort auf: bansalmP529H
What version of Revit are you using as in previous version if the data could not be written/sorted it was blank and it looks like some of these row may relate to missing information?
In newer version you get the message <varies> so you may need another level of sorting!
Also in the Sorting Tab there is an option for Blank Line as well as the formatting Tab
Jay Colcombe
Autodesk Certified Instructor
