HI everyone:
My name is will,
I have Revit 2023 and 2024 in my computer.
I build a model at Revit 2024 , and I want to directlink to Twinmotion 2023.3.1,
but the twinmotion button still greyed out even when I was in 3D view.
I have tried to reinstall both Revit and Twinmotion ,but it still doesn't work.
I also tried download the datasmith plugin for Revit 2023 , but my model was built in Revit 2024 so it cant be opened.
Is it because I have two version of Revit ?
Does anyone have run into the same situation before ?
2023 and 2024 are not using the same version of twinmotion and datasmith.
Will, did you get a response to your inquiry? I have the same set up as you (Revit 2023, 2024) and still have not being able to figure out how to "open in twinmotion" from revit 2024.
My issue is resolved. I downloaded the update from Revit 2024 and the update from twinmotion (epic games). Hope that helps.
