REVIT 2024 Repeating Detail Component invisible while placing
ty_po
Message 1 of 13
ty_po
Noticed when using repeating detail component in Revit 2024, it is invisible while placing. it's not until I have finished placing that it becomes visible. also goes back to invisible when I select it. I have never had an issues with previous versions.
Replies (12)
Message 2 of 13
GaryOrrMBI
Same here.
Changing graphics options, theme, view visual styles, view detail level, etc. all make no difference.
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Message 3 of 13
michaelPMGKQ
Observer
Observer
Got the same issue. Does anyone know a fix.
Message 4 of 13
ty_po
I'm going to say its a bug/glitch as with every new release of revit there tends to be something not working properly until they fix it
Message 5 of 13
GaryOrrMBI
All we can hope is that someone from Autodesk will read the post, if it goes without getting marked as solved long enough, and get a fix worked into the next patch.
-G
Gary J. Orr
Message 6 of 13
Message 7 of 13
michaelPMGKQ
Observer
Observer
Message 8 of 13
ngs_shane
incase it helps anyone, i have the same problem as described above. but with the additional issue repeating detail components are not printing.
In the print settings, 'Hidden Line Views' Remove Lines Using: Vector/Raster processing. our standard is to use raster processing. however swapping to vector processing, the repeating detail items then get printed. i will have to do some additional testing to see what effects it has on the rest of our documentation.
Message 9 of 13
Jorge_escamillaLPG54
Community Visitor
Community Visitor
In our case, we set our Print Setup, Hidden Line Views to Raster Processing...that seem to work.
Message 10 of 13
ty_po
The new Revit 2024 update has now fixed the issue
Message 11 of 13
Lachlan.mckiernan
Did you figure out a solution to the non-printing repeating details?
Message 12 of 13
ngs_shane
The latest update patch resolved the issue.
Message 13 of 13
michaelPMGKQ
Observer
Observer
I reported the issue to Autodesk in April 2023 and it was resolved in update 2024.1 Thank you.
