hi ,
whenever i click on material icon nothing pops up and all the materials textures are missing whenever i try to assign one to any item. where can i reinstall is from ?
have you checked this already?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-material-bro....
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
I can't see which Revit hotfix version you have? Latest is 2024.2
If you don't have that one, I suggest opening Autodesk Access and installing all updates that have Revit 2024 in it's name. Since it's clearly some kind of bug preventing Materials to open and newest hotfix might fix it.
And also in Autodesk Access, be sure to change filter to All
try to repair your revit program nad see if helps.
if you want to install the latest updates from autodesk go the bottom right corner of your screen
https://bimsmith.com/help/learning-revit/How-to-Use-Revit-Material-Libraries
