Revit 2024 Realistic Problem
5 ANTWORTEN 5
Nachricht 1 von 6
harunananias
620 Aufrufe, 5 Antworten
I have a problem that started a few days ago, before everything was working fine.
In Realistic View, I´m losing shadowing and depth. Even in the same View I have zones of the model that work ok, and other zones where I lose the realistic effect.
I have updated to Revit 2024.1, but I still have the same problem.
I use
ASUS TUF Dash F15 12th Gen Intel(R) Core(TM) i7-12650H 2.30 GHz, 16,0 GB
NVIDIA GeForce RTX 3060, 6GB GDDR6, Windows 11 Home
On the Image Im posting (All in Realistic View):
N1 : Shows 2 house models in the same view, one working well, the other with errors.
N2 : Shows the same view rotated, the problem switches between house models
N3 : Same as N2 but in a different angle
N4: Zoom-in to the model working with correct shadows and deph of Realistic View
N5: Same house model, left side of the house with errors and right side is correct, If I turn the view, it changes.
N6: Zoom-in to the model working with with errors
5 ANTWORTEN 5
Nachricht 2 von 6
L.Maas
als Antwort auf: harunananias
What happens when you restart Revit and/or Computer?
What happens when you create a new 3D view?
Also look at updating your graphics card drivers.
In File>Options>Hardware deselect hardware acceleration
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 6
harunananias
als Antwort auf: L.Maas
Restarting Revit and Computer doesn't fix the problem.
Duplicated 3D views from the bugged view gives the same problem.
Already tried the Hardware deselect hardware acceleration option.
Nachricht 4 von 6
L.Maas
Does it happen with other projects?
Does it happen when using the project on another computer?
Louis
Nachricht 5 von 6
harunananias
For now it's happening only with this project, but It happens in any computer.
Nachricht 6 von 6
L.Maas
Seem like a bug somewhere. I would recommend to submit a support ticket in your Autodesk account. Maybe the Autodesk people can have a look at your project.
Louis
