REVIT 2024 - possible BUG
4 ANTWORTEN 4
Nachricht 1 von 5
aRcHiTeCt.JM
1388 Aufrufe, 4 Antworten
REVIT 2024
first impression is good.
*** The only thing I found wrong is the following:
Every time I print a PDF of a set of plans, the program freezes after a while and I have to close it completely.
After REVIT is closed, the computer saves the PDF or prints the sheet set. (sometimes)
I have been trying to PDF with several projects and it is the same. (for me)
but REVIT has already been closed and you have to reopen it
ANNOYING !!
is this a bug?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
4 ANTWORTEN 4
Nachricht 2 von 5
Sean_Page
als Antwort auf: aRcHiTeCt.JM
I am getting that error when trying to open, but my issue appears to be references it can't find. CefSharp.Core being the main one.
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Nachricht 3 von 5
Yien_Chao
early releases are always for the public to find bugs.
Nachricht 4 von 5
stevecrotty
Could we get some more information on the original post? You mentioned it was any time you print a set of plans. Your image shows the sample file. Have you tried multiple other files, views, and printers? Is a specific view or file a possibility or is it any set of views in any project to any printer? A journal or report would help us take a look.
Nachricht 5 von 5
RobDraw
I like Guinea pigs and would like to take this opportunity thank all of them.
Rob
