Hello, running into a strange issue with this year's version of Revit on our instant clones. What happens is that everything works fine on the Golden Image, but once the clones are created opening Revit 2024 leads to an empty gray window and none of the buttons do anything. Even trying to open or start a new project looks like the interactive window that would pop up for details is not running. In fact, the only way to open a project is to drag and drop a file into the window. Even after loading a scene this way though, the user cannot interact with it in any way.
Has anyone else run into this or have any suggestions?
This is an issue with VMWare or your IT.
Had a similar issue (for me the properties bar didn't work when remoted in). the issue appeared out of nowhere in R2023. I have an alternative way to remote in via VPNN and that didn't have that problem IIRC. I even worked with Autodesk support to exclude any Autodesk issue.
I don't know how our IT made changes, but at some point it worked again a few weeks later. that's why we have 2 ways to remote in... at any given time one of the 2 options is flaky...... For a few weeks VMWare also was blocked from use due to security issues. So, that doesn't seem to be the greatest software...
