So I just installed Revit 2024 and I'll leave the illegible graphics for another post already started!
Here I'd like to review some kind of "glitch" in the two lower left pull downs in the Material Browser. This is the only area I have discovered this issue. Please add if you see similar.
Scenario: When I select either of the lower left pull downs in the Material Browser or have my cursor roll over it, the information or the pull down appear on the opposite monitor than the one I am working on. See attached image.
Set Up: I use Revit and most programs mainly on my Right monitor and have other applications or dialogue boxes open on the left, as needed.
Clarity of Scenario: Image Displays Revit and Material Browser on Right Monitor and the pull down appears on the left monitor, see image. But, if I move the Material Browser to the Left monitor, the pull downs work normally. On the flip side, if I switch Revit over to the Left Monitor, and the Material Browser is also on the left, the pull downs are normal. But if I have Revit on the Left and move the Material Browser on the Right, the Pull down menus show up incorrectly again.
So does anyone have any idea about what is going on here? Is there some setting that Revit wants for Multi-monitor support? NOTE: I also have a WACOM Cintiq Pro as a 3rd Monitor, but is usually off when using Revit.
Specs: I use a NVIDIA GTX 1080ti - (I know, my card is old!) The driver version is 528.49. (I rolled it back to this version due to a problem I was experiencing with ZBrush and Lumion.) Note, the Newest driver, as of this date, had the same performance.
