Revit 2024 - Line Patterns are being duplicated
AnnaK246
AnnaK246
I'm having an annoying issue on a model hosted on Autodesk Docs.
When I edit some families and then sync, I see a warning that some elements name were automatically changed/duplicated. Using an analysis tool I've pinpointed the worst offenders to the Level Line pattern (Dash Dot). These are nested/shared families.  When I make any changes to the family and sync, it's duplicating the Dash Dot line pattern and adding a number to the end - I'm up to hundreds of them, even though these Level Lines have never been altered and they all have the same pattern. I've deleted the duplicates, but can anyone help me figure out why this would be happening and how to stop it happening again?
Thank you
azad.Nanva
that because your family can not be loaded in your central project ,that be loaded only in your project or vice versa.
in my opinion when you change or renew your family open your central project and parts and use the "Load to Project" and that can stop the problem happen.
But I use the links en i think the links is too much better than central project.
