I Have installed new version 2024 of rivet. i cannot load rivet families. i try to dowland and install 2024 family , but i cannot install properly. any solution ?
You can also access the larger cloud library directly inside Revit.
Load Autodesk Family
Browse for a Family
You can select more than one at a time and load into the project.
Since Revit 2022, the default family are all cloud base. @jay_colcombe post is exactly how you load the family. If you want to local Revit family content, you have to manually install them. You can download the content from the link below
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
