From one point of view, and for no reason at all, the original Revit was presented with an unrecoverable error message that forced the program to close. Tried everything, including full disclosure of Revit, as well as any plugins. Once reinstalled all the new errors that appeared ideologically and start the program (concurring the logo of the program, since it is not here). The following indicates the error file in case anyone can help. Thank you so much.
Fecha/hora: 2023-05-15 18:34:58 +02:00
Aplicación: Revit.exe
Error: Access violation - code c0000005 (first/second chance not available)
Nombre de módulo bloqueado: mscorlib.dll
Dirección de excepción: 0x00007fffd23daf98
Código de excepción: c0000005
Indicadores de excepción: 80
Parámetros de excepción: 0, 10
Tipo de excepción administrada: System.NullReferenceException
Dirección de excepción administrada: 0x000001589a82cbe8
Gelöst! Gehe zur Lösung
Gelöst von miguelangel.godoy. Gehe zur Lösung
Autoresponse with the solution.
I reinstall Windows 11 and everything is perfect. Also (at least in my case) it is the fastest way to fix this kind of strange problems. A real shame of OS (I guess). And that was practically empty. Maybe some **** update.
