Revit 2024 Batch Plot Freezing
JDixonIDEA
JDixonIDEA
I was testing out Revit 2024 with the new architecture sample project and tried to export all of the sheets as pdf using the template's sheet set for all sheets. When I hit plot/export to pdf Revit starts plotting the first sheet then gets hung up and will not continue. I waited for 20 min and nothing changed.
Has anyone else had any issues plotting the sample project?
mhiserZFHXS
I had the same problem yesterday, but it did eventually finish. Probably took about 30 minutes.
