Revit_2024_2_0.exe
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
SergioPecoraro
1099 Aufrufe, 7 Antworten
Revit_2024_2_0.exe
I did the procedures to download the Twimotion installer and tried to update Revit 2024 to the most current version.
After 2 attempts, it reached 97% when installing the update and crashed. Now Revit does not open and displays the message: "Revit was unable to load C:\Program Files\Autodesk\Revit 2024\IntfIFC>dll. The Program will now exit." Clicking OK aborts, closes and is no longer possible to open Revit.
Can anyone help me please?
7 ANTWORTEN 7
Nachricht 2 von 8
ravwood
als Antwort auf: SergioPecoraro
Sergio have you checked you have enough space in the C drive.
Nachricht 3 von 8
ennujozlagam
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-could-not-lo...
Nachricht 4 von 8
SergioPecoraro
als Antwort auf: ravwood
Hi! 100Gb free.
Nachricht 5 von 8
ravwood
Noted Sergio. Please can i ask if you are sure in task manager all autodesk related exe are closed when the installation is being done. If even after closing all prgorams and background processes the same issue persists then can i request if we download the install once again and then try. Thank you
Nachricht 6 von 8
Myself and at least one other at my company have experienced this issue. For one the fix was to reset to a Restore Point before the download, for me I didn't have a restore point that would work so the only fix wipe the machine and reinstall everything. To get Revit 2024.2 on and working was to fully download the install before actually installing it.
Nachricht 7 von 8
I waisted 2 days trying to uninstall and reinstall, and Revit wouldn't uninstall correctly.
So in the end the wipe and reinstall only took an afternoon.
Nachricht 8 von 8
SergioPecoraro
als Antwort auf: ennujozlagam
thank you guys
