Revit 2023: Why the added level doesn’t get in line with other levels on the 3D?
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
JamaL9722060
567 Aufrufe, 9 Antworten
For example, in the screenshots below, as level 4 is added, it doesn’t get in line with other levels.
How this can be controlled?
Jamal Numan
9 ANTWORTEN 9
Nachricht 2 von 10
RSomppi
als Antwort auf: JamaL9722060
Why not just copy an existing level with the extents as you like?
Nachricht 3 von 10
You can copy the level instead place a new one.  Or, assign them to the same scope box.
Nachricht 4 von 10
syman2000
Check this video how to control your grid and understand how it works. Your grid comes in 3d and 2d setting. The minute you drag the 3d element, the extent of the level changes globally. If you aren't careful, you will get mis-match level at your 3d view.
https://www.youtube.com/watch?v=OM0PTfGrp_0&ab_channel=PracticalBIMResources
Nachricht 5 von 10
JamaL9722060
Copying the level doesn’t create new level as per the screenshots below. The created level remains dark but not blue
What could be the issue here?
Jamal Numan
Nachricht 6 von 10
Add a new plan view associated to the new level and it will turn blue.
Nachricht 7 von 10
JamaL9722060
I couldn’t figure out how to “add new plan view associated to the new level. How this can be performed?
Jamal Numan
Nachricht 8 von 10
View > Plan Views > Floor Plan
Nachricht 9 von 10
SteveKStafford
Create a new floor plan view, choose the new level from the list: View ribbon > Plan View > Floor Plan
Steve Stafford
Nachricht 10 von 10
JamaL9722060
It works fine. Many thanks
Jamal Numan
