My 2023 revit with not allow me to move surface patterns using the dimension command. I first encountered this with ceiling grinds. Clicking of a grid and dragging it works as does the align command but clicking on a grid, moving the cursor to the side and inputting a dimension does not. I found that it works to input dims in my 2021 version but not a 2023 upgraded version of the same model. A little more investigation shows I also cannot move surface patterns (e.g. brick coursing) in 2023 using a dimension but can drag/align it.
Gelöst! Gehe zur Lösung
Gelöst von kenplautz. Gehe zur Lösung
Found the solution. In the move command the disjoint button needs to be unchecked. You can't do this while trying to move a surface as it is grayed out. You need to uncheck the disjoint button while in the move command.
http://architects-desktop.blogspot.com/2015/01/revit-ceiling-pattern-will-not-move.html
