Revit 2023 shuts down when adding Windows, doors, curtain walls.
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
sgurteki2
269 Aufrufe, 2 Antworten
Hello everyone,
I would like to reach out to the Autodesk community regarding an issue I have been experiencing with Revit 2023 on my recently upgraded Dell Precision Laptop. While working on my new project, I have encountered a recurring problem whenever I attempt to add curtain walls, windows, or doors to my model. The view in which I am making these additions consistently shuts down automatically, accompanied by an error message. Upon attempting to reopen the affected view, it appears distorted and unusable.
I have attempted various troubleshooting steps, including trying different versions of Revit such as the 2022 version and working on other projects. Additionally, I have restarted my PC, but unfortunately, the issue persists.
I would greatly appreciate any insights or suggestions from the community regarding the possible causes of this problem and any preventive measures I could take. Your expertise and guidance would be immensely valuable in resolving this matter.
Thank you for your time and assistance.
Kind regards,
Seda
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: sgurteki2
try to install latest updates from autodesk and update your graphics card driver to the latest and see if helps. thanks
https://help.autodesk.com/view/RVT/2023/ENU/?guid=RevitReleaseNotes_2023updates_html
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/3Pqlb4rdjevhFzlBcWw8SC.html
Nachricht 3 von 3
sgurteki2
Hi ennu,
I'm going to try this. Let's see if it will work. Thank you for your support. :siegeszeichen:
Kind Regards,
Seda
