AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Revit 2023 "Encounters serious error" when trying to change a Design Option to Primary
8 ANTWORTEN 8
Nachricht 1 von 9
matthewJVP4M
479 Aufrufe, 8 Antworten
Title says it all. Revit build 23.0.10.18; model is a Workshared Cloud Model. When trying to make a Design Option a Primary Pption, I get this error message. I can select "no" and continue working in the model, but still cannot make a Design Option a Primary Option. As such, I don't know what will happen when I then Accept Primary. Anyone else having this issue?
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: matthewJVP4M
Could it be a permissions issue?
Nachricht 3 von 9
matthewJVP4M
als Antwort auf: barthbradley
I doubt it. I've never encountered permissions issues before, so I don't know what it would even look like if it was.
Nachricht 4 von 9
I'm talking about Workset permissions.
Nachricht 5 von 9
matthewJVP4M
All elements in the option are on the same Workset, which is also the main workset we are using for the model, so I don't know what issues that could cause.
Nachricht 6 von 9
maybe an issue like you're having? Dunno.  Just running it up the flagpole.
Nachricht 7 von 9
Go through Warnings under Manage tab and try to resolve as many as you can, particularly the ones related to design options.
Nachricht 8 von 9
What about CUT/PASTE from DO to Main? That work? It's a valid approach.
Move Elements from One Design Option to Another | Revit 2016 | Autodesk Knowledge Network
Nachricht 9 von 9
matthewJVP4M
It likely would, and that was the path I was saving for last. I was just looking to see if anyone else had any issues with Making Primary options with R23.
In Foren verƶffentlichen
