Revit 2023 - Missing Keynote Family
brantyork.design
brantyork.design
I am trying to use keynotes, but the file does not seem to exist. How can I manually load a text file as the keynote file, instead of using the file that Revit comes with (which is missing)?
I have already checked to see of the file resides in "C:\ProgramData\Autodesk\RVT 2023\Libraries\English" and it does not.
Help is appreciated thank you!
Metric keynote text file is under Imperial library for some reason. Check here:
c:\ProgramData\Autodesk\RVT 2023\Libraries\English-Imperial\RevitKeynotes_Metric.txt
brantyork.design
Yeah it wasn't in that folder either! Very strange. But thank you for the txt file, ill add it to that location!
disposetogetrid
Community Visitor
Community Visitor
I turned into capable of restore this by using adding a PrintManager within the DWF part of the code and then disposing it after the export. I suppose the export have to were protecting on to a number of the print sources inflicting the PDF print to now not paintings however I'm no longer completely certain as I have test it with my page.
constantin.stroescu
You can modify the existing keynotes in a text or you can create your own custom keynote (as part of your office standard) by using a text editor:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-D...
you can see bellow  an  example of such a file I've created for using in my office  :
https://www.youtube.com/watch?v=21RavTam718
Constantin Stroescu
