Hey All,
Not sure if anyone else is having this issue? I have a Material Tag Family with type parameters which alter the shape of the tag. So currently I have 1 Material tag family in my project, 3 different types of that 1 family. If I change the tag from an Ellipse to a Diamond and then Tag something, it tags a Diamond but then reverts back to the Ellipse for the next tag. If I then cancel the function and restart it, it remembers the last type used and uses that i.e. Diamond.
As this requires you to keep changing the type parameter each time after the initial use of the function, it is somewhat frustrating. I am wondering if there is some intention there in the functionality that isn't quite working right? This family didn't behave this way in 2022.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Something is wrong with the Family. Probably a formula. Post the Family. I'm sure we can fix it.
...wait a minute! Are you saying the parameter that controls the diamond and ellipse is a Type Parameter and that you only have ONE TYPE. If so, create another TYPE - one with Diamond and one with Ellipse.
...BTW: last Type used is the default for subsequent Types. So, that behavior is correct.
Hi BarthBradley,
As mentioned: " I have 1 Material tag family in my project, 3 different types of that 1 family."
There are no formulas in the family. it is a simple Visibility parameter.
Please have a look and see if the problem is duplicated on your end.
Unfortunately, I can't get it to screw up. I tried my damnedess too. It works beautifully.
