Hi Everyone,
Wish I could be more specific, but this is not my area of expertise. Revit has frozen about 4 times on me today. I cannot click on anything in the any open window, I cannot activate any key commands. Just frozen solid in all ways. I can toggle between open windows that are in my task bar, but that it is.
The freezes usually happen when I am in the middle of executing a string of high speed commands.
For some reason I am suspicious it is getting locked up in the middle of an autosave prompt. My suspicion is based on two pieces of evidence:
A) revit has no regard for the current command when it prompts autosave, it just pushes the autosave through whatever you are doing, and it won't let you continue until you accept or reject the suggestion. Obnoxious behavior to begin with, but it also creates the semblence of a frozen program when the autosave prompt is pending.
B) The last file was exactly 15 minutes older than the current time of the latest crash. I have my autosave prompts set to 15 minute intervals.
I have no ability to submit an error report, there is no autosaved file, the program does not crash. Thought I'd post, dunno what else to do.
Hank
@a.henry.rose wrote:The freezes usually happen when I am in the middle of executing a string of high speed commands.
Synch before doing such things to avoid the reminder prompt.
Extend the time. It won't stop the prompt but it won't happen as often.
@a.henry.rose wrote:this is not my area of expertise. Revit has frozen about 4 times on me today.
Revit does not have an Autosave feature. Are you sure you're using Revit?
