I have noticed two issues related to the new dialog for selecting the Export as IFC Entity through family type/instance properties.
Firstly, if the dialog is left opened (whether by editing the type or instance properties) and then Revit is temporarily left for another application and then one returns back to Revit, the Export as IFC Entity dialogue has the tendency to disappear (...behind the Revit application window? IDK). It is a bit finicky to get this back or to even exit it as there is no available icon in the windows taskbar. Alt-Tabbing a couple times eventually brings it back but it should really stay in the foreground like any other dialog.
The second issue, is apparent when opening the same dialog through family type properties. If the Export Type to IFC As is previously populated with a value, then subsequently selecting a predefined type in the dialog has no effect on the actual Type IFC Predefined Type parameter without first clicking Reset, OK and then re-opening the dialogue and then re-populating both Parameters at the same time before clicking OK.
A further point... I expected that clicking next to the Type IFC Predefined Type parameter would open the same dialog, but it opens nothing... bug?
Thanks for the ALT-TAB suggestion. Had the exact same issue.
...definitely needs improvement. I'd report it to Autodesk directly.
