Revit 2023: How to combine the material takeoff schedules in one table?
I couldn’t figure out if there is a way to combine all the material takeoff schedules in one table such that as any item (wall, door, window, etc.) is sketched it gets integrated in the table.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
It appears that the “base constraint” field is not available under the “multi-categories” option which indicates for the “level” in case of “walls”.
Why such field is not shown up in case of multi-categories” option?
