Revit 2023 hanging on loading model
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Hamel_BS
948 Aufrufe, 3 Antworten
I have a project with multiple Revit 2023 models, for some reason all the models although only a few MBs in size take well over 10mins to load.
Having checked the journal files I am seeing that it is hanging longest at these parts, but not quite sure what its telling me. Weirdly, it seems, I am the only one getting this issue with the models. Other peoples computers seems fly through these parts of the journal with out no stalling.
'E 25-Mar-2023 21:32:36.435; 6:<
' [Jrn.ExternalResourceLoad] Rvt.Attr.ExternalResourceType: cf823dbb-21d2-42e0-a39c-1cb523a8cec2 0
' 8:< Unnecessary nesting;E:\Ship\2023_px64\Source\Revit\PersistenceDB\Document\PostLoadDocument.cpp;203;String_Revit_DelayedPropagatoinRegen ;N++E(N);
' 9:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 9:< RAM Statistics: 110511 / 131016 1235=InUse 1249=Peak
' 9:< VM Statistics: 134177222 / 134217727 1163=InUse 1164=Peak
' 9:< Element Expansion Statistics:
' 9:< 0% Opening Plans (0)
' 9:< 0% Opening RC Plans (0)
' 9:< 0% Opening 3d Views (0)
' 9:< 0% Opening Elevations and Sections (0)
' 9:< 0% In Regnerate (0)
' 9:< 0% In Autojoin (0)
' 9:< 0% In Overlap Checking (0)
' 9:< 0% Reviewing PostedWarnings (0)
' 9:< 100% Other (1616953)
' 9:< total bytes expanded: 1616953
' 9:< ;EES;0;0;0;0;0;0;0;0;100;
' 9:< s_alreadyLoading loadingLinkedFile LinkLoadingFailureProcessor
' 7:< Unnecessary nesting;E:\Ship\2023_px64\Source\Revit\PersistenceDB\Document\PostLoadDocument.cpp;538;ID_SETTINGS_SNAPPING ;N++E(N);
' 8:< ::74:: Delta VM: Avail +23 -> 134177245 MB, Used -3 -> 1161 MB, Peak +0 -> 1164 MB; RAM: Avail +66 -> 110578 MB, Used -1 -> 1234 MB
' 8:< GUI Resource Usage GDI: Avail 9769, Used 231, User: Used 253
'E 25-Mar-2023 21:34:03.485; 8:<
'C 25-Mar-2023 21:41:18.457; 8:< The current load request is an automated one.
' 7:< ::87:: Delta VM: Avail +2 -> 134177120 MB, Used 1245 MB; RAM: Avail +53 -> 110924 MB, Used 1305 MB
' 7:< GUI Resource Usage GDI: Avail 9769, Used 231, User: Used 247
'209.314718 8:<<<Keynoting Settings -> readFile
' 8:< ::87:: Delta VM: Avail 134177120 MB, Used 1245 MB; RAM: Avail +24 -> 110949 MB, Used 1305 MB
' 8:< GUI Resource Usage GDI: Avail 9769, Used 231, User: Used 247
'E 25-Mar-2023 21:44:45.815; 8:<
If anyone could shed some light on what might be happening, please let me know.
Hamel
3 ANTWORTEN 3
Nachricht 2 von 4
FuldenYilmaz
als Antwort auf: Hamel_BS
 Your problem may be related to some add-ins. You can examine the cause and solution from the link below;
 Revit'te Cloud Workshared veya Non-Workshared modelinin yavaş açılması (autodesk.com)
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Best regards,
Fulden Yılmaz MSc. Architect - BIM Consultant
LinkedIn
Nachricht 3 von 4
Hamel_BS
als Antwort auf: FuldenYilmaz
Hi Thanks for your help with this.
So after quite abit of testing, i found the issue was to do with this line of the journal..
It was hanging at this point for a very long time and realised that the model file I had was pointing to a keynote file which was being hosted somewhere on the internet on another companies domain. But that alone wasn't the issue. It was the fact that I way using a VPN and because the other companies domain was probably blocking me entry due the use of a VPN. After I disabled the VPN i found that it worked completely fine and didnt hang at this point.
Hope that helps anyone else who runs into this issue.
Nachricht 4 von 4
ben.carlson
Hi @Hamel_BS - we may be running into this issue in R2022 (though not related to VPN). How did you determine the keynote file was hosted somewhere else?
This accounts for 8 minutes:
    'E 14-Sep-2023 11:12:07.134;   8:<
    ' [Jrn.TaggedInLinkRehosting] 1 , 0Rvt.Attr.TagCategory: Room Tags Rvt.Attr.TaggedElementClass: RoomElem Rvt.Attr.TaggedElementCategory: Rooms Rvt.Attr.HostDocumentType: NotWorkshared
  '  3.135119        6:<<;PERF;MISC;regenerating
  ' 14.897421      4:<<loadLinkedDocuments [8]/ALL_GAPS   2.742481/TurnOff_GAPs 50%/Threshold_GAPs 2%
  ' 4:< ::12208:: Delta VM: Avail -46 -> 134202420 MB, Used +75 -> 8578 MB; RAM: Avail -536 -> 11139 MB, Used +9 -> 7292 MB
  ' 4:< GUI Resource Usage GDI: Avail 8942, Used 1058, User: Used 476
  '490.817087!!!!! 4:!!!BIG_GAP [Cloud]postLoadDocument
  ' 3:< Unnecessary nesting;E:\Ship\2022_px64\Source\Revit\PersistenceDB\Document\PostLoadDocument.cpp;502;ID_SETTINGS_SNAPPING ;N++E(N);
    'E 14-Sep-2023 11:20:18.143;   4:<
    ' [Jrn.ExternalResourceLoad] Rvt.Attr.ExternalResourceType: b6305212-4915-4526-b659-be2d6f97174f Rvt.Attr.ExternalResourceServer: bd4f0f53-394a-4468-b37e-1e7949013382      0
