Revit 2023. Error while copying View with Detail Groups among models
3 ANTWORTEN 3
Nachricht 1 von 4
druiz4BEDN
299 Aufrufe, 3 Antworten
I open a source model and a destination model in Revit 2023.  I then use copy and paste to copy a Drafting View from the source model to the destination model and get this error:
When I copy other Drafting views that have no detail groups in them,  the view is copied correctly, but if I copy views that include Detail Groups, I get this error and cannot proceed.
I do not encounter this error when I try the same operation on older Revit versions. This only happens on Revit 2023.
3 ANTWORTEN 3
Nachricht 2 von 4
druiz4BEDN
als Antwort auf: druiz4BEDN
Note, If I try to copy the content by using INSERT -> Insert from File, I am able to copy the content successfully from one file to another.
To replicate this, you can try copying these views to another model
from the 2023 project file, I am attaching.
Nachricht 3 von 4
Lance.Coffey
Thank you for the question @druiz4BEDN!
I’ve been able to reproduce the error with the provided model and logged this behavior with our developers.
The issue has been documented in the following article (and the article will be updated as there are changes in the status of the investigation): Error “Changes to groups are only allowed during Edit Group mode” when pasting drafting view in Revi...
In the meantime, continue using the Insert Views from File command to work around the current behavior.
Lance Coffey
Technical Support Specialist
Nachricht 4 von 4
druiz4BEDN
als Antwort auf: Lance.Coffey
Thank you. I hope this issue can be fixed soon.
