Revit 2023+2024 crahes when opening ANY project
2 ANTWORTEN 2
Nachricht 1 von 3
emil.walter
268 Aufrufe, 2 Antworten
Same problem with Revit 2023+2024:
Program starts up fine and families can be opened, no problem. But as soon as I open a new project (existing or new) the program crashes with a no response error.
Windows 11, newest version, definitly meets the minimum requirements.
Revit 2023+2024 are freshly installed (never opened a project before on this PC).
Other Autodesk products (AutoCAD) are working fine.
What can I do?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: emil.walter
Open a support ticket through your autodesk.manage.com account portal - or contact your Autodesk reseller.  That would probably be the fastest way to resolve in this case.
Nachricht 3 von 3
handjonathan
Hi @emil.walter
Thanks a lot for posting your question to the forums!   The first thing to check is to ensure you have all the updates installed.
If that does not solve it, look here for more possible solutions.
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
