I have no idea of what happened for this to occur but majority of glazing in my windows/doors have turned green. They used to be grey. I simply opened Revit one day and they were green. No settings were changed. I tried to then edit the family, change the color, the type of glazing etc. but it still remains green. I tried restarting but nothing seems to work. I opened a few other projects and same issue. One elevation shows the correct window color (gable end)
Only showing green in elevations ,sections, realistic views.
Thanks in advanced!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Textures Visual Style is my guess.
....actually, I'm thinking Graphics Card. Did you recently update driver?
Looks like my countertops which are made using generic model-in-place, are showing up green as well.
Thank you for this. I turned off hardware acceleration and re-opened the project and my windows are now looking normal. When I turn it back on, the windows are green again.
Is there a way to solve this without turning hardware acceleration off? I would like to keep it turned on
It's a hardware issue. As I said before: Graphics Card.
...I asked if you recently updated driver. If you did, roll-back the update.
I did just perform a windows 11 update but was experiencing this issue before hand. I proceeded with the update in hopes it might fix the issue.
@drayden2W36M wrote:I did just perform a windows 11 update but was experiencing this issue before hand. I proceeded with the update in hopes it might fix the issue.
Contact Autodesk about this. Open a support case through your autodesk.manage.com account portal.
