Revit 2022 - where are the family templates?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
HVAC-Novice
2063 Aufrufe, 3 Antworten
When I create a new family, I usually use the generic filmily template (the face based, or un-hosted depending on what I need. then i convert that to the category I need (e.g. mechanical, plumbing etc.).
I do have whatever imperial family content Revit gave me and also re-installed that from here. Still no family template.
Is it located somewhere else or can I download it somewhere?
There also used to be several line-based family templates etc. but the generic face and unhosted one is what I need now.
Revit version: R2025.4
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: HVAC-Novice
Nachricht 3 von 4
HVAC-Novice
als Antwort auf: ToanDN
Thanks. I got it.
I now know what happened. I hadn't realized this is the path for family templates and assumed it would be a location for project templates. So in my infinite wisdom I changed that path to where I have my project templates.
Nachricht 4 von 4
If all else fails, there is no drawback to using an earlier version Template. It'll upgrade upon opening.  FWIW.
