Every time when I print to pdf the text notes move from their position and overlap. I tried to fix it in the print configuration but the only change that i achived was to move it in diferent directions. This only hapen whit the text notes that are rotated in vertical.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
try another pdf printer like BULLZIP and see if helps. thanks
