https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Opening-...
The above article decribes exactly the problem we are experienceing, however, the solution for this listed by autodesk is completely unacceptable. we dont place links for fun, they are generally crutical consultant information and need to be turned on. Its as if Autodesks solution to a tyre puncture is to remove the wheel.
has anyone else had this issue with 2022, and do you have any workarounds?
Anyone at autodesk able to help? (echo, echo, echo...)
