Revit 2022 on Win 11 Home
7 ANTWORTEN 7
Nachricht 1 von 8
jakub4
518 Aufrufe, 7 Antworten
Has anyone had any issues running Revit 2022 on Win 11 Home? Do I need to upgrade to Pro?
Cheers,
J
7 ANTWORTEN 7
Nachricht 2 von 8
RobDraw
als Antwort auf: jakub4
What kind of issues?
What makes you think that they are OS related?
Rob
Nachricht 3 von 8
jakub4
als Antwort auf: RobDraw
Apparently only Windows Pro and Windows Enterprise are listed under Revit system requirements. I am about to buy a laptop that comes with Win 11 home and was wondering if I will have to upgrade to Pro for Revit to work.
J
Nachricht 4 von 8
I can't speak for Windows 11 Home but I have been using multiple Revit versions in Windows 10 Home without any issues.  So if you are working by yourself then I wouldn't be worried. But if you use the laptop in a corporate environment then Pro is recommended.
Nachricht 5 von 8
Nachricht 6 von 8
This is good question, @jakub4.  Autodesk doesn't make mention of Win 11 Home.  You ought to contact Autodesk directly about this by opening a Support Case through your Account Portal.
Post here what they tell you. It'll help others who have the same question.
Option B would be to contact your Autodesk Reseller. They should know.
Nachricht 7 von 8
jakub4
Thanks, I will contact Autodesk
Nachricht 8 von 8
jakub4
That's the response...
