My problem is whenever I click the "File" tab in Revit 2022 (to Save, Open etc), the program is not responding.
I have used some workaround, like deleting the log, which had some short term effect, however reading in the forum I thought this problem was fixed with the updated, while it is not.
Any suggestion?
Open revit.ini and delete any lines under Recent files and under Worksets.
Thank you, I did that, but it does not last long.
I was wondering if there was a more permanent solution.
Do you have any add-ins?
