Revit 2022 Material browser appearance tab keeps updating
1 ANTWORT 1
Nachricht 1 von 2
469 Aufrufe, 1 Antwort
I am using Revit 2022. As I open the material browser window, it works fine and then stuck for a few seconds. Also, when I switch to the appearance tab, it keeps updating with no further change. My GPU is GT555M (391.35 Driver-latest) and Intel 3000HD (Latest Driver). The weird thing is that when I switch to Intel 3000HD, it works fine, which is absolutely the wicker Graphic Card. Please Help me with this problem.
Beschriftungen (2)
1 ANTWORT 1
Nachricht 2 von 2
Clint.Billstrom
als Antwort auf: Anonymous
So I was having this problem as well, and I definitely didn't want to use my integrated gpu. Took me a while, but just duplicating the material and then editing immediately solved the problem. It only gets stuck updating if I try to edit the default materials.
Sorry it took so long, hopefully helps someone else
