Revit 2022 - Including grids within IFC-Export
katarina_rozic
Observer Observer
katarina_rozic
Observer
Observer
for our project I want to export the created project grid as IFC export. However, the grids are not displayed in the exported file.
Under Settings I have already selected the IFC type "ifc Grid" for the grid. However, the grid is not exported here either.
Is there a way to export the grids as ifc?
Thank you for your help!
tmoibe.digbandjoa46MK5
Hi, I had the same issue. It is known by Autodesk and the Solution that they propose is to upgrade to R24 because it was resolved there.
My solution is to use model lines to draw your Grids before the export to IFC.  I also use 3D text to write the grid name.
